This is relay pissing me off now. (Clicking mega fast)
Djw John
Scotland - South
This one, injection relay I believe.
Earths are good, checked in several different ways.
It's a new loom but seems to be about the same as the old one. Kinda doing my head in diagnosing it now as I keep chasing one problem away and getting 2 in return!
What should I be checking? The green wire seems to be the switched one and is giving out 5V. I've checked with several relays and they all do the same.
Things what I've done;
Changed the loom for another one (apparently also from a ph2 172)
Cleaned all the earths
Checked the injector earths
Checked the relay earth and also tapped into it which has stopped the clicking.
It hasn't solved the solid red light or pump not pruning issue. I can only start it with the relay removed and a can of brake cleaner.
Jesus I must have been tired last night, thats not the white plug I was on about. That plug comes on an earlier loom so you'll have a later 03 onwards engine loom. Not entirely sure what it does but a CAN test with CLIP might bring something up
Yeah I figured you meant the main white one.
It's a f**king weird one. Seems I can have the fuel pump working so long as the injection system isn't powered.
Aye that is a weird one haha, I can't remember what that grey plug energises now. Its defintely something to do with starting the car though so that will likely be your issue
@Inferno182 send this man a late PH2 engine loom👀😂
Changed the ecu, uch and key today after not having a chance to look at this for months. Relay no longer going bonkers so that's good
Immob light was flashing like mad so wouldn't start. Went out for a few hours and when we came home I thought I'd try again. Solid red light.
I mean this from the bottom of my heart when I say f**k CLIOS.
Check your earths
Yeah, it's your issue now.
So you've got a starting point, I got it with a solid red light and blowing fuses for fun.
Changed the loom, no red light issues but fuel pump relay going bonkers and had the choice of pump or injectiors.
Changed the ecu, uch and key to lead to a fast immob light.
Went out for a few hours, whilst I was gone the f**k you gremlins visited and changed it to a constant red light.
Long story short, f**k cars.
So it fired up after changing the ECU, but just had a loud relay?
All of the ecu, uch and key are a matching set?
The decoder ring usually gives the flashing inmob light, but i think it's often just a bad key battery rather than a faulty ring. Try changing this first then unlock and lock the car with the key in the ignition before cycling it again for a minute through the ignition sequence (without actually starting the car). Did you only get the one with the new uch?
Next up check you're getting 5v at the ring and then I'd be going over all the earths again, including hunting for damaged/worn wires between ecu and big white plug.
Ignition stage two for 60 seconds
Ignition off (but key kept in) for 30 seconds
Ignition stage two for 30 seconds
Key removed, count to five, then try to fire up
So it fired up after changing the ECU, but just had a loud relay? The fuel pump relay was clicking at a rate of about 6 per second, it meant the fuel pump wouldn't run but I could start the car on brake clean being squirted in. With the relay out the injectors would run but the pump wouldn't.
All of the ecu, uch and key are a matching set? Yup
The decoder ring usually gives the flashing inmob light, but i think it's often just a bad key battery rather than a faulty ring. Try changing this first then unlock and lock the car with the key in the ignition before cycling it again for a minute through the ignition sequence (without actually starting the car). Did you only get the one with the new uch? Yeah done all that.
Next up check you're getting 5v at the ring and then I'd be going over all the earths again, including hunting for damaged/worn wires between ecu and big white plug. The new loom was checked before fitting for condition and all seems good. The fact that is has fired albeit with a spray of brake clean gives me some hope but not much
I'll give that a bash in the morning, I've disconnected the battery and simply cannot be arsed going out in the rain for more disappointment 😂 thanks though, I'll update tomorrow.
It's not anymore. Read it again!
That was the previous loom which had many many shorts in it.
Now it has a good loom, good ecu, good uch, good key, good relays and fuses and still WONT f**king RUN!!!!!1!122!111'53224211!!!!!
I had this when I changed my battery and it was as if it lost the communication between everything so gave me a solid red light.
I just kept unlocking the car and putting the key in the barrel and it eventually coded together
Well, tried it. No fire of any sort. Yet.
I've now left the battery connected and will try again later
It only f**king runs!!
Fiddled with plugs then the tb started making a whining noise, still wouldn't start, hit it with a hammer and it stopped making the noise then started up 🤣🤣🤣🤣
Still plenty to do it but at least it's now worthwhile doing.
