I really like those. Where did you get them from?
Clio cup race car.I really like those. Where did you get them from?
As above, on the cup racers. The previous owner fitted them not me.I really like those. Where did you get them from?
Cooking the brakes on the way to work? You've got a much more exciting commute than i do!
f**king poser👀😂I have some 100mm bass ports. It's only for aesthetics, so I have no ducting behind it, just mesh. The most annoying part is they face slightly inwards and not straight and it backs onto the fogs, but for £6 it's a cheap option and I'm sure many have made backing plates and ducting for it to work.
Get them done in abs not pla. I'll be honest that's the first set that I've heard that are meltingI’m using a 3D printed replica of the OEM flog lights that have a straight profile so the airflow is direct to the wheel arch. These were done by TrackSpec, I have had to cover the offside one in kevlar sheet to stop it melting from radiated heat when the vehicle is parked up.
I’d like to get a set of these made up in alloy as I think they offer the cleanest looking ducts I’ve seen so far. Obviously a duct with a scoop will take maximum advantage of the air displaced by the frontal area of the car, but seeing as nobody does a quality item yet, I’ll wait. View attachment 1512126View attachment 1512127View attachment 1512128
Group buy time?
But they don't look like they fit👀I’m using a 3D printed replica of the OEM flog lights that have a straight profile so the airflow is direct to the wheel arch. These were done by TrackSpec, I have had to cover the offside one in kevlar sheet to stop it melting from radiated heat when the vehicle is parked up.
Which bit?But they don't look like they fit👀
The bit around the edge where it doesn't fit😂Which bit?
You mean the actual OEM surround? 😂The bit around the edge where it doesn't fit😂
Nah the gap around the side of the foglight surround😂You mean the actual OEM surround? 😂
That’s Renault for you mate, call Dieppe and ask them. 😅
Same gap as what’s there on a foglight. They measure the same. Just not as obvious with the lamps in.Nah the gap around the side of the foglight surround😂
True never thought of it that way😂Same gap as what’s there on a foglight. They measure the same. Just not as obvious with the lamps in.
All of the sexualness lol.Wouldn't it look better if the 3D part was wider than the fog light cut out? Then it would look like a smooth entrance (giggidy) from the front and the 3D part would mount the hole from the rear
Trying to say our cars look s**t now?If I could get a better set made up that fit even better I’d be delighted. These were off the peg for the 197/200. As I know the fogs on those were a carry over part from the mk2 Clio, I decided to take a punt. Room for improvement, yes, but certainly some of the better looking variants I’ve seen so far.
