Sunflower Ph1 172
If/when I do a suspension/bush refresh on the Ph1, am thinking about getting a spare front subframe and getting that shotblasted and powdercoated to swap over at the same time.
Will I need to source a Ph1 front subframe? Do they differ to Ph2 172/182 subframes? Have tried to search but information is not clear. I believe I do need to source a Ph1 subframe as they are slightly narrower than the Ph2 (hence 172 Cup driveshafts being slightly too long for a Ph1) but if somebody could confirm?
As for wishbones, RPD sell Ph1 wishbones (apparently different to Ph2) - but I plan on fitting Cup wishbones and I am sure this is what I fitted to my last Ph1 and they fitted fine, but just want to confirm this is the case and there would be no issues?
Thanks,
Ash
Thanks,
Ash
