Help diagnosing a problem
Car  Clio 182 FF
Hey,
Just wondering if someone can help diagnosing a problem I have with my steering.
For ages i’ve had this problem, whenever I turn right the steering pulls me in more. Basically turning left is fine, go to turn right and I have to hold on tight as I don’t know what the steering is going to do.
When dry steering, you can hear a knock. And you can feel the knock when holding the lower arm.
Also at the last track day I had the car at, the power steering fluid was over the inside of the bonnet. When I opened the reservoir up it was sitting just above full and wasn’t particularly hot to touch. I’m guessing there’s air getting into the system?
Recently I have changed lots of things for new parts. None have fixed the problem.
New lower arms.
New ball joints.
New Steering rack bushes.
New drive shafts
New wheels and tyres
I’ve also had the wheels aligned using a place with a proper laser setup.
So my next theory is it’s the steering rack? Maybe pump?
Or if the overflowing steering fluid is a normal thing during hard driving and not related, then top mounts?
I should add.
The knock and the overflowing fluid are new problems that have only started (or I’ve only noticed them).
Also the last time I drove the car it was raining and it seemed way worse! When it dried up later on in the day, it wasn’t as noticeable.
Fluid boiling over is pretty common on track.
If you think there's air, remove the cap and go from lock to lock a dozen times or so to help bleed any out.
Not sure about the pulling on right turns though :unsure: are you on standard suspension?
Have you got a print out of your current alignment?
The car is an FF car. Running on Koni springs and cup shocks. Here’s a print out of the alignment I had done.
It’s feels too much to just be alignment. The car drives in a straight line no problem.
Would a dodgy top mount effect the steering at all?
Thanks. I’ll change the top mounts next to see how I get on. Guessing fitting a new rack would be a big job.
Try jacking the car up and turning the steering using the wheels from side to side.
Should be able to feel something if there's a problem.
New rack would be a subframe off job.
