Alternator Needed - Hard to find one that matches
  Clio 2.0 138hp
Hopefully someone can help me either find the correct part, or at least the right part number.
Ive got a Clio MK3 2.0 NON-SPORT, it needs a new alternator pretty soon. Its a 120A Bosch unit currently but i cannot find one the same anywhere. Ive seen that some of the 197's use the 120 A units but with a 7 rib pully rather than the 6 i need.
Im sure there are other cars with the M4R engine fitted that have the same alternator but i cant find them.
So if someone knows where i can get a suitable part, or if i could get the sport unit and swap the pulley over that would great.
If anyone actually has the part i need, please let me know.
  172 Ph1
Do you have a M4R700 engine number ??
If so the part number could be
231000012R
Have a scout about for one .
Put that number in some search engines .
Hope this helps .
  Clio 2.0 138hp
231000012R
Hope this helps .
Thanks for the reply. It didnt return any results, but it did bring up a few different units that are supposed to fit. So ive gone with a europarts version that is for the 1.6 engine as they appear to be the same
MarcB
  Too Many
@rbeazer if you PM me your original Reg or chassis number and I will check the genuine OE parts system for your car.
MarcB
  Too Many
There is a choice of two.
Genuine New or Re-con from the dealer.
I have sent @rbeazer a PM with all the OE part numbers along with all the info he needs and some images and links to buy non genuine.
  Clio 2.0 138hp
This man is a legend. Sorted me right out with all the part numbers i could need. Top man
