Power Steering Hoses Pipes - Where are all the spares!?
  2003 Clio 172 Cup
Hi all. I can’t find any stores, online or otherwise that have the high pressure and return hoses for the 172/182. After 4 hours all I can find is the £175 high pressure upgrade from advocult and one secondhand return line.
Am I missing something? Are these hoses the same on all Mk2 Clios? Has anyone replaced these recently? Where did you source the parts?
PS just spent 30 minutes with local Renault dealer and they can’t ID the parts. They’re now going to call Renault HQ to see if they can work it out.
HELP!?!? 🤣
Yarp
  182 Turbo, E46 M3
Which one do you need? I’ve got a full set from when I removed my PAS but had to cut the one that goes on a mission over the top of the gearbox to get it out.
Martin_172
just take the original to Pirtek and get them to make a replacement, as long as its roughly the same length you can just run it on a similar route to the original. I seen one recently on a mk1 kangoo where someone had a pirtek hose and it was just ran over the top of the engine and then down to the rack, that gave me a laugh!
  2003 Clio 172 Cup
Lots of people have said Pirtek. I’ve found a local place too. Going to take the bumper off later so I can change my headlights at the same time. And pop down in the morning.
