Help - 182 blowers not working
Andy_con
Car  clio 182
car was fine yesterday but this morning the blowers have decided to die!!
control unit/console in the car turns on and everything works, just the blowers are dead.
whats the general advice and things to try before taking it to a garage?
cheers
checked the fuses and its not them
anyone got any clues what these fuses and relays are for?
Think that there is some kind of resistor under the scuttle panel. Often fails due to water damage. There is a thread in the common faults/fixes section I think. Replacement part is around £35 from renault.
i would bet my wang it is this, mine went a couple of months back, ordered one from clio spares and fixed in ten mins.lift the scuttle on the left and it is the big connector on the right.
you can bridge 2 terminals out and get it to work to prove it is this. cant remember which ones though. do a search.
ok i replaced the transistor on the resistor pack and ive gone from dead blowers to a small amount of air coming out which is a start i suppose.
where is the fan located on the 182, i need to check its not stuck or blocked?
am i looking at the right place on the below pics?
if so how do i get access to it?
im assuming the filter ive taken out here is the pollen filter?
im assuming this is the fan?
how do i get full access to it?
first u need to take the water catcher off where the white clip is at bottom of window driver side after thats off you can see 2 x 6mm bolts take them out and fan should just slide out and theres a black and red wires going in to it
@andy_con . Did you sort your fan problem out, replace it?
I think my fans going titsup. It was making a bit of a rattling sound and I could smell a burning plastic smell.
Resistors fine as I have full control over the speed.
Fans easy to replace
I haven't had chance to look today as it's not stopped pissing down.
I don't suppose you have the part number for a 182 with air con ? It seems there are quite a few different ones some for air con some for none air con.
No sorry, I'm sure there is info on cs somewhere
Old thread here but can anyone tell me / show me with pictures how to get the actual blower fan u it out?
I have no blowers working at all, replaces resistor (as i have in the past) and still not working the blowers this time. Although the new reaistor did make some sort of clicking noise happen. Maybe a duff resistor?
I did a half arsed explanation with pics when I changed my fan.
Post #6
