172/182 Cup Spoiler Brake Light
Fishfire
  Clio 172
I'm trying to find a brake light for a 172/182 Cup Spoiler.
Bought a Cup spoiler recently and just got round to testing the brake light, which is dead as dodo.
I know you can retrofit LED strips into the existing lense, but I don't think the brake light is going to come out in one piece (I've already put a small crack in it trying to gently prise it out 🤦)
I know Renault have stopped making these, but I'm hoping someone may be able to point me in the right direction to find either a working light of a good condition lense I can retrofit an LED into.
I know this has been done a lot, but I've drawn a total blank on replacing my dead one.
Cheers!
rs 1an
South East - Essex
They are about Fishfire, this is my spare in case i get a 182 one day but you can see the part number etc.
Fishfire
  Clio 172
They're rarer than hens teeth!
Definitely not manufactured anymore by Renault. I spent most of the day phoning various Renault dealers, specialists and Renault Clio breakers......not a sausage, no new old stock, no second hand ones nada!
On a plus note I've got my brake light out, and can confirm that the LED strip is totally FUBAR 😏
Coops Mk1
  Lots of Scrap...
I've got a brand new in box one I'd consider parting with, pop me an offer on pm but it'll need to be in the triple digits tbh
Fishfire
  Clio 172
Ah, I appreciate the offer but that's a little more ££ than I can justify on a light tbh.
I've rescued the lense on mine, although the LEDs are fried. I'll put a new LED strip in there which has worked for a few people from what I've read 😁
  Clio 182
Boys , use a 300mm 12v led light strip from Toolstation.
Works a treat.
I used the spine of a dvd case to stick LEDs to, and then wedged that into original red valeo light housing. Original metal clips then hold it in place nicely. Leave the original circuit board out.
Use solder and heat shrink. Don't just twist wires together for gods sake.
  172 Cup & 172 Turbo
Works a treat.
Use solder and heat shrink. Don't just twist wires together for gods sake.View attachment 1627794
Do you have a link to what you used?
  Clio 182
Here you go
  Clio 182
Be careful pulling/levering the clear red plastic lamp housing out of the spoiler. Don't want to crack it obviously.
Just gently lever out on alternating sides with something that will spread the pressure a bit.
