You can change the hue and saturation of the camera itself if you log onto its ip
What nvr do you have? You maybe be at the bandwidth threshold of streaming with the colourvu. That's one of the reasons I went for a 16 channel nvr it has higher bandwidth (double what the 4 and maybe 8 channels one have)It's got so well...
I noticed this morning I couldn't view colourvu on the app, so went to check the nvr and it's there. Double clicked for full screen and just a black screen
Is the camera to new for my nvr, does it need an update? Not that I know how to do that.
Unplug all the other devices and just try and run the new one is the quickest solution check to this, I’d imagine?What nvr do you have? You maybe be at the bandwidth threshold of streaming with the colourvu. That's one of the reasons I went for a 16 channel nvr it has higher bandwidth (double what the 4 and maybe 8 channels one have)
Could be that's that's your bottleneck then. I'd test it as per robs suggestion
Ffs... More money.Could be that's that's your bottleneck then. I'd test it as per robs suggestion
What about the other way around? If you unplug the dark fighters does the colourvu work on the app?Ffs... More money.
If I unplug the colourvu, the dark fighter works on the app.
So what do I need to buy then![]()
eazycctv.co.uk
16 channels seems a bit extreme for just 4 cameras, could I not get away with 8 channels?What about the other way around? If you unplug the dark fighters does the colourvu work on the app?
I went for this one
EazyCCTV.co.uk
Secure your premises with EazyCCTV's high-quality surveillance solutions. As experts in CCTV systems, we offer a range of reliable, cost-effective options to fit your needs. Whether you're looking to protect your home, office, or commercial property, we have the expertise and experience to help...eazycctv.co.uk
I've just checked and the 8 channel version does have half the bandwidth16 channels seems a bit extreme for just 4 cameras, could I not get away with 8 channels?
And how about t’other way around? Just to rule out individual cameras?Ffs... More money.
half the bandwidth compared to what?I've just checked and the 8 channel version does have half the bandwidth
You may be able to get away with the one you have now just reduce the streaming quality a bit, it's an option but to me it negates the point of having a decent camera.
will check in a bitAnd how about t’other way around? Just to rule out individual cameras?
Half the bandwidth of the 16 channel unit. That's why I went for the 16 channel one.half the bandwidth compared to what?
i dont want to reduce quality, as i might as well have got cheaper cameras![]()
this one looks good, if im reading rightHalf the bandwidth of the 16 channel unit. That's why I went for the 16 channel one.
The one I have is 256mbps but that because I have 4 of those cameras.so here is the spec of mine, its 40mbps bandwidth
this newer one is 128mbps bandwidth and is cheaper than the 16 channel NVR
True, am just out. I'll have to check when I get home what the cameras kick out data wise to see how much band width 4 would useThe one I have is 256mbps but that because I have 4 of those cameras.
Just depends if you think you'll be upgrading the rest in the future I suppose.
Did you try this?And how about t’other way around? Just to rule out individual cameras?
yes, colourvu works fineDid you try this?
What cameras you got?So got a new hikvision nvr and it will not pick up the cameras?
Lost on what to do?
3x hikvision camerasWhat cameras you got?
Turn on ONVIF on the cameras should help.
Can you lay out the schematic for me?3x hikvision cameras
Just unplugged my old hikvision nvr and plugged a brand new one in.Can you lay out the schematic for me?
What are cameras plugged into?
What is the NVR plugged into.
Should work then.Just unplugged my old hikvision nvr and plugged a brand new one in.
Got Internet connection and the app working.
Cameras are plugged straight into the nvr.
Getting power fine they are showing on poe page.Should work then.
You gone into settings and scanned for the cameras? Did you have passwords set up on them?
Need to scan for them and then if needed log into them.
Presume they are getting power via nvr and cameras are active?
admin, 12345.Getting power fine they are showing on poe page.
Think it's some kind of password issue.
I didn't have one set previously![]()
admin, 12345.
If not, use SADP
Do you have a POE switch? as will make this much easier otherwise youll need to get to every camera and reset it inside the dome/unit.SADP
www.hikvision.com
Video:
password reset:
I think I need some cameras around the house and have been recommended Eufy set up.
Any pros/ cons, or anything better? They look half decent - was thinking of doing the doorbell camera package like this one, plus 2 extra cameras?
Front Door Best Bundle
With eufyCam S220 (eufyCam 2C Pro) and Video Doorbell Dual 2K (Battery-Powered) Add-on Unit See even the tiniest details outside your home with Front Door Security Bundle. Watch anyone arrive with eufyCam S220 (eufyCam 2C Pro), then greet them at your door with Video Doorbell Dual 2K...uk.eufy.com
But there is a huge cost different between a hikvision setup and eufy
Hey your talking to the converted, I have a full hikvision system, but I get not everyone can afford it or doesn't want to spend that sort of money.Probably but I live by buy cheap pay twice
My system was fitted couple of years ago & just does what it says on the tin.
Factor in your time f@@king about fixing problems not so cheap & still working to get it fully functional.
It’s already helped a neighbour when their car was damaged as I supplied high res photos for them.
Oh military grade encryption they boast about is BS
