Mr Trailer Man
Is there only one sensor on this car?
Not uncommon to be one for the ECU and a separate one for the dash gauge.
The dash gauge gets it from the coolant temp sensor via the ECU.
Not sure about the wiring, I'll need to check that. The battery was new 2020 after lock down. I think it is a decent make if I remember right.
I'm tempted to just chuck a new sensor in it![]()
Yeah genuine sensor and thermostat from Renault. Bit annoying if it has gone alreadyWas it a genuine coolant temp sensor you fitted the last time?
All made of finest chinesium thin steel now i guess.
the guys that installed it said it was original. Anyway, the one I instlled now is 100% original as I did the jobO.e or aftermarket?
On the older cars they used to stick closed which was bad so id say breaking or sticking open is the better out of the two, but still sh*te.
