Rear pad / discs
Car  RS Clio Cup172
Over the years has anyone found one manufacturer better than any other for rear discs?
Due to their low braking adhesion they rust and mine now have gone to the stage they need replacing but at £300 I am wondering whats the best solution?
I have no records of the last set that went on mine.
Or you could buy the Motrio rear discs and pads which are still genuine Renault.
Used and suppled for cars that are 10+ years old.
Just fitted these they do the job
I've just went for Brembo. £60 a disk with bearings, and £18 for pads. With delivery it was less that £150.
In the past, the problem with those has been that the bearings are usually cheap s**t that don't last at all and was cheaper in the long run to just buy genuine Renault items, just not sure if the same logic can be applied now that Renault items are even more expensive
Those are even more expensive 🤣🤣
Just buy SNR ones
Need to be careful with those if you've got ABS, fcuk knows why Renault did it but the ABS rings are different on the lower spec models so the discs themselves have different part numbers despite the disc & bearing being the exact same part on all models :rolleyes:
Following on from what's been discussed above.
A friend is needing rear discs and pads, and was shocked when I seen the genuine parts prices, so attempting to find a cheaper alternative..
I've tried to price up discs without bearings and SNR bearings today.
Turns out it's only EBC that sell them without bearings and SNR are avaliable separately but even these paired together is coming out at close on £200 trade.
If anyone’s looking for rear discs we sell the proven brembos Here
We stock a few different rear pad options too and now we’re set up as ‘traders’ on here we will look to help out with cliosport members where we can - just get in touch.
  • Like
Reactions: FOY
I just got some Delphi ones from GSF for £67 a side. Not sure if that's good or bad, but they look ok.
I’d read that the bearings in some (not to say the ones you’ve got) don’t last. And that Brembo has the same bearing as OEM?
Not sure how true this is though.
I’m replacing my rear calipers so am just biting the bullet and doing everything 🥴
I've read this too. I spent ages looking for some decent ones but just bit the bullet with these. Time will tell I guess :ROFLMAO:
I had a pagid one fail on me back in 2021, only two years old. Might be luck of the draw perhaps.
I've read this too. I spent ages looking for some decent ones but just bit the bullet with these. Time will tell!
I had a pagid one fail on me back in 2021, only two years olds. Might be luck of the draw perhaps.
My mates a Brembo dealer so am enquiring with him.
Don’t really want a wheel falling off ideally 🥴😆
As long as it has the SNR bearing you are will be fine, Renault have used SNR bearings for years on there cars and come standard from factory stamped with SNR
