I did not know that!I imagine lots of folk know this already but figured out the other day you can fit a normal hacksaw blade to a recip saw.
Real handy if you need to bend round a corner slightly to get down a tight gap.
My M12 6.0ah battery appears to have s**t itself, I’ve barely used it and now the fucker won’t charge![]()
Do you have a fast or slow charger?
Mine is sometimes fussy with the fast charger, so I do the M12 stuff with the slow.
Or you could try jumping it with another M12 if you have one.
Whats it doing flashing red and green? If so try leaving it on the charger for a good while then taking it off and putting it back on again
Did you have it inserted (hehehe) in a tool?Exactly that, will give that a try too![]()
Not reallyNope, always disconnect the battery. This particular battery was mainly used for the leaf blower if that makes any difference?
Tanks easy to drop on a 182, rather do that than use a sheet metal nibbler on it.
Edit - sorry, they are sheers. You can get nibblers even cheaper that go in your hand drill but I still wouldn't vs just dropping the tank unless its very crusty.
I did think of that after posting I’ve got a decent set in the garage so might give it a go with that first.Would a decent pair of tin snips not work?
Ahh my bad, yea snip snip.It’s the mk3 shitter and I’d have to take the whole exhaust off as it’s one piece and the rear brake lines which is a hassle just to swap the pump.
If it was a mk2 it’d be a piece of piss to change I cannot fathom why Renault decided to make the access hole smaller on the mk3. Bloody French.
DRILL NIBBLER
I haven't used one this s**t before but have used a nice air one and it flew through the 1mm sheet steel I was cutting.
M12FIR38-0I need a decent electric ratchet. I have lots of 3/8 & 1/4 sockets. Any recommendations? Nothing heavy duty.
M12FIR38-0
Typical. No discount on that one.M12FIR38-0
I use it regularly and its gotna lot more oomph than you would think and thats just a 2 ahr batteryCheers chaps. Went for the M12FHIR38-0 and the higher powered battery.
It’s not for my car, but a project I’m starting with a lot of bolts. It’ll save me a lot of time. Thank you for the codeI use it regularly and its gotna lot more oomph than you would think and thats just a 2 ahr battery
I'm tempted by this bundle to help me disassemble the clio (and throw it over the fence).
Milwaukee M18FPP3P-6524P 3pc Fuel Fastening Power Pack in Packout Case - PowerToolMate
www.powertoolmate.co.uk
Good value at £540?
Good value thatI'm tempted by this bundle to help me disassemble the clio (and throw it over the fence).
Good value at £540?
Not sure the 18v impact adds much the 12v stubby doesn’t tbh.
