CLIO RS, SAT NAV- Disconnected.
Wolvessmith70
  Renault Clio RS
63 plate, Clio RS. Menu- only Sat nav greyed out. Able to access all other options as usual. Tried new SD card- no change.
Nothing obvious, been told to check fuses, water ingress etc. Electrician’s advice was ‘needle in a haystack.’
Anyone else had same problem? R link? Evolution.
Thanks.
Gus
  182Turbo,DCi90
I'm pretty sure there is a setting somewhere to disable it. I know I can disable it on the medianav in the settings menu.
Wolvessmith70
  Renault Clio RS
Thanks, I might have to. Just looking on R link store for updates. It states ‘ you can no longer subscribe to a connected product service. Your vehicle is not eligible for connectivity’
Does that go some way to explaining? There aren’t any updates, no maps nothing?
Pacman.
  Did have a R27
Need to take it to Renault for an update. I have to do that with my Twingo with r link
Wolvessmith70
  Renault Clio RS
No phone linked yet as did a factory reset just earlier. There is an SD card in but nothing seen?
Sash
  A Yellow One
I have a feeling you need the SD card that I have.
It contains an update. Where are you located?
Sash
  A Yellow One
How different is it? Bought it from a reputable dealer, looked at files on comp, has all necessary on it but my R link just not reading it?
The card I have is a dealer update card. Technically it’s not mine 🫣 so I can’t just send it off to anyone as I do have to return it at some point. Might be worth popping into your local dealer and asking them?
Martin_172
perform an update using Rlink Toolbox, I had this issue and that solved it
Wolvessmith70
  Renault Clio RS
Hi Martin, thanks, downloaded toolbox, went to updates.. no map updates? Only agreements. Map side empty? There is a red bar across top of screen stating I am ‘no longer able to subscribe to a connected product. My vehicle is not eligible for connectivity.’ Is this the main problem? It’s driving me crackers! Have it booked in to Renault in a month but in mean time trying to resolve without spending a fortune!
Martin_172
If you have a good as card don't worry about map updates, it's system updates your looking for
