Car 'squeak'
ex-Chinese Dave
Car  172 Cup
This is an odd one. I've just had a suspension refresh (4 dampers, springs, ARB bushes, top mounts, track and steering rod ends, ball joints) and the car feels great. There are no knocks or bangs and going over speed bumps etc sounds and feels like it should. But there is a squeaking/chirping noise that seems to come from the whole car. It only does it if the car judders or shakes. It is not from the engine or gearbox. It can do it at any speed but it needs the same conditions to make it heard. One time it sounds like its from the osf, the next from under the steering and sometimes it sounds like the boot is not closed and is wobbling. I'm guessing it's always done it and the new parts have made it more noticeable. I searched on CS going back years and I didn't find anything that related. The car has also just had an MOT. The only noise I can think is similar is from my mates 206 GTi and you can hear it when you lightly wobble the exhaust tailpipe with the engine off (I think the flexi joint on his exhaust is worn near the CAT).
Any ideas as to what it could be? It's not life threatening but it reminds you that your car is 21 years old!
There are only two at the front, maybe your squeak is coming from the extras.
I would lay under the car and get someone to shake it about, often its the exhaust joint.
I'm thinking the exhaust, too. It has a new hanger at the rear but the sound is like that of my mates car. What can be done if its that? (I can get under it neat week)
I rocked the engine hard in all directions and it's solid, no noises or anything. I've rocked all four corners of the car hard, with and without the handbrake on, and nothing. I've had the boot open and shook it in all directions, nothing. I've opened the doors and done the same without a squeak or knock heard. I've shook the exhaust in all directions without a peep. I've had the engine running and been on and off the biting point on the clutch without the sound being heard (sigh). I've driven down a road at 10 mph and turned the steering wheel left and right quickly and nothing. Going over speed bumps there's nothing heard at all. I think you get the idea.
But....
....when the body of the car shudders whilst driving over a hole or undulation I hear the squeaking. It's not loud but it seems to come from the corners (the wheel areas). I've had the suspension refresh as stated above. It almost sounds like it's the springs that slide a little in their recesses. Does that make sense? Should there be something between the ends of the spring and where they sit that prevents this noise, or is it just spring on metal with the weight of the car holding them tight? It's an odd one but I'm sure it can only be spring related (Eibach Sportlines are fitted).
Do your springs still have the coil isolators (plastic spring sleeves) intact?
They serve multiple purposes - mainly noise reduction - stops the metal on the spring tips and damper from coming into contact with each other. They also help with Vibration dampening, spring wear and corrosion.
I don’t know but this is what I think might be causing the noise. I’ll have to get under the car at weekend and have a look. I didn’t have those on my list of suspension parts to change, so maybe they were not on the car when I had the work done.
Do you have a part number for these in case I don’t have them? And I’m guessing it’s a strip down of the suspension to change/fit these, right?
They usually come with the spring - see a picture of something similar. The factory springs had a clear piece of sleeve fitted both ends of the coil.
I have the Eibach Pro_kit springs on mine and they don't have them as standard, so i bought some plastic sleeves off eBay. Just to stop the end of the coil rubbing against the metal seats at the base of the damper.
Might not be that, but it's possible. And yes, it's a case of removing the damper from the hub and taking the spring off. Try spraying some WD-40 or GT 85 in between the spring and damper first. See if that cures it. If it does, invest in some of those sleeves.
I got secondhand Eibachs and they didn’t have any plastic on the ends.
Yes, I was thinking about some PTFE spare or similar to try first.
Cheers.
So, today I jacked up the car and had a good look at the O/S/F suspension and bits. The noise seems to be coming from the front O/S as opposed to all four corners, which is what I thought was happening until recently. All very odd.
The chaps at Birchdown fitted my new suspension parts recently and I have 100% faith in what they did. Nothing looked loose, damaged or out of place. The secondhand Eibachs I bought were in good condition although they had a flat area where they had rubbed together previously (before I got them). I had bought two cheap rubber sleeves that can be fitted around a spring without removing it from the car. I fiited one on the O/S/F over where the spring is flattened (about 2 coils up if you know what I mean) and then had a drive. It’s definitely made a difference in reducing the strange noise although not completely. It may be that I fit a sleeve that covers the entire spring again without removing the strut and dismantling it all. It’s all a bit odd but the noise can only be coming from the springs.
Update on this oddity...
I fitted one of the sleeves to the O/S spring and it 'seemed' to make a difference, although the squeak is still there. Birchdown say it may be the top mounts (they are new original parts fitted) and this makes sense as I didn't hear this noise before they were changed. I've read back on CS and some suggested lubricating the mounts. There is actually nowhere to lubricate them apart from a squirt of WD40 in the gap between the rubber part of the mount and the suspension turret. I've done that and will drive the car later.....
A quick update:
I did some work on my car this week and gave a decent squirt of WD in the gap between the top mounts and turret. I sprayed into the gap from a few different angles. It had been on axle stands for a few days so maybe that has also allowed the WD to get where it was needed. Driving the car now there is no squeaking noise.
Bonus!
Update of this ongoing tw.at!
The WD40 didn't last too long until the noise returned, so a few weeks ago I squirted some bike chain lube in the space between the top mounts and the turrets. It made a huge difference but as expected it ran down over my springs. During the past week, as the weather has been dry, the noise has got a lot worse, probably as the lube has run away. There doesn't seem to be anything to hold any form of lubrication in place. Today I tried something different. I have some dielectric grease (bought to solve another issue would you believe!) and I've used a small brush to get some into the gap (as per pic) between the top mount and turret. It made a massive difference and should last longer but I can sometimes hear the noise still. I'm convinced it's being caused by the rubber on the turret but I've not read anything of this kind of issue on CS before. And just to add to the mystery sometimes it sounds as if the squeak is coming from inside my door!! It's utter madness!!
Just curious, any update here? Are we talking about a Clio 172/182?
I have the same issue after installing apex springs. Have replaced with new top mounts and same issue. Squeaking is driving me nuts
Sorry for the late reply as I’ve only just seen this.
A few weeks back I had Birchdown replace the top engine mount, the big one on the left side when you stand in front of the car looking at the engine, with a good condition OEM secondhand mount. After this was fitted I did not hear the squeaking noise. I noticed that there was a lot more vibration through the car when the engine was running and I can only conclude that this would be normal and that the original engine mount was completely shagged. I did write that most of the sound seem to be coming from the right front of the car. The car is at Birchdown today and it’s having a brand-new OEM mount fitted, along with some other jobs. I’ll report later after I have driven home but I’m sure the squeak was caused by the engine mount. I had had almost all of the suspension components replaced and maybe the weak original engine mount was then being exposed.
So the new mounts were fitted today (second-hand lower gearbox mount, brand new OEM top and upper gearbox mount), drove home and the squeaking noise has not returned. It had to have been the old original mount that was 'found out' after everything else was renewed.
