Windscreen seals.
Matt Cup
  Leon Cupra
Can someone do me a favour and take a picture of the scuttle window seal so I can compare them to mine. I refitted mine the other day annd noticed it doesn’t seem to fit properly in the corners after having a new window and side/upper seals fitted.
Also it’s popped out at the top I assume I can just pop a bit of silicone in there to hold it down?
Cheers.
Matt Cup
  Leon Cupra
Scuttle panel trim sits on top from memory.
You might be able to just lift the corners over.
Cheers I tried that. But it seemed to leave quite a gap down the length of the seal. It’s almost like if I trim the corner off it’ll sit flush.
Matt Cup
  Leon Cupra
Unless they changed the design?
Just need some pics of others as comparison.
I do remember my old screen having two blobs of putty which may have held the scuttle down?
Louis
I Love Ed Sheeran
Thanks Louis.
So one corner folded in and one resting on top. 😝
You also have the exact same bit of side trim not fitting properly.
Yeah but mines fucked 😂
There's little clips underneath that you can bend to house the end parts
Matt Cup
  Leon Cupra
Yeah but basing mine on yours mines fucked too 😂
The end bits that attach to the top seal are clipped in fine, it’s just one is bulging like in your pic.
I am more bothered about the bottom though.
Louis
I Love Ed Sheeran
Compare 1st picture to 2nd. I bashed it in after taking the 2nd photo.
Your bottom isn't right, they look too high.
Matt Cup
  Leon Cupra
Thanks both.
Going to get a bit of double sided tape to get rid of the gap. 👍
Matt Cup
  Leon Cupra
I'm 95% sure there's clips on the edge of the scuttle plastic that holds it down and they're never there.
There are, some white ones. I think I was missing an outer one and swapped one of the inner ones for it.
These
And it’s missing one too.
But as you can see it doesn’t clip near the corners.
Matt Cup
  Leon Cupra
Had a bit more of a play with this over the past few days.
Bought another scuttle panel and put some double sided tape to hold the passenger side down.
Greeny.
  440i + 182
Mine are taped down with black electrical tape on the outside 😀 the edge clips do little on mine despite being there
