Has anyone rattle canned their front bumper?
ex-Chinese Dave
If you did how did it go? What were the results? etc
My Cup's front bumper is pretty bad for stone chips and has a bad crack under a headlight that someone has tried to repair before...badly! I've had it off before (ooh err missus!) and it's not in bad condition apart from the above problems. I'm considering flattening it off, repairing the chips and crack, and then spraying it myself with rattle cans and then a lacquer. I really don't want to touch the paint on the car despite road rash and all that as it's original and is with the character of a 22 year old car.
ex-Chinese Dave
That would be an issue. It may be better for me to try and repair the crack first and see how it matches up. Do you know the paint code and a good brand to use?
KitsonRis
I rattle can’d the bumper on my Ph1.
Does it look better than it did - yes.
Could it be better without a proper respray - no.
Do I regret doing it - no.
I only did it as the whole bumper was like flat and faded and no amount of polish was going to get it back. Did a few coats of plastic primer, sanded it back, few coats of silver, flat it back on the first few coats, lacquer on top. Came out alright for a quick job. Only did it to make the car pass the 10ft test which it now does. But the whole car needs a respray so was only a stop gap fix.
ex-Chinese Dave
Yeah, I'm very tempted as a lot of jobs have gone to Birchdown as I just don't have the space to do a bit myself. I want to do as much as I can for the personal satisfaction as I do like to tinker, to a limit. I've just repaired the original splitter and it's not a bad attempt IMO. To make this car mint would take a full respray which just isn't on the cards, but if I can get it better than it is at the mo i'll be happy. The wiper arms need doing too as they are badly chipped.
Gally
massiveCoRbyn
  Several
If you wantmit to look good, save your time and effort and put it in a bodyshop. Rattle can finish generally looks crap and chips very easily.
This is the thing I have noticed. For some reason, when I've painted stuff with a gun and compressor, it has been wayyyyyy more durable than stuff done with rattle cans.
Matt Cup
  Leon Cupra
Thats pretty obvious tbf. There are an infinite amount of adjustments with a compressor and a gun you just need to get that right along with the correct ratio of paint and hardener. Where you are at the mercy of the nozzle quality (this varies quite a bit) and pressure dropping with aerosol.
ex-Chinese Dave
I'd never try and rattle can a panel as I agree that trying to get a uniform coverage over a large surface area would be very difficult. The front bumper has so many different contours that break up the surface area so would be much easier although not easy. And yeah, it's a good point about the pressure dropping off in a can and the nozzle spray pattern being a bit random. Still, as my bumper doesn't pass the 20 foot test I'm sure I can get it to pass the 10 footer.
