Yay, another problem!
Advikaz
Went to get my tyre replaced this morning.
Got home and noticed water pouring out of the car and steaming from the bay.
Just about to jack it up and take a look.
Thoughts ?
  • IMG_4854.mov
    17 MB
NorthloopCup
That’s a lot of water coming out mate! No coolant pipes at the back of the engine except for heater matrix. Can’t distinguish which side it’s coming from, but could stat housing, heater pipes or water pump.
Advikaz
Brigsy
  T.Turbo
If you want to use it before fitting new hoses, chop pipe and stick a bit of copper pipe in to join.
botfch
  Clio 182
Straightforward enough, some of the pipes are a pita to get off but if you don’t care about keeping them can just cut them.
Colin-S
  172 Cup
Has anything sharp been rubbing on that? or even if it was a small hole would the pressure then make it look so much worse?
Good luck getting it fixed in time.
Advikaz
Nothing in the vicinity mate.
I would guess it’s just fatigue (20 odd year old hoses)
Brigsy
  T.Turbo
How do you get these clips off the heater matrix pipes? Is this the PITA aspect of it?View attachment 1742347
Set of snips or careful cut with a dremel.
Id not disturb the fittings off the heater as the o rings are most likely shagged with age. If the fittings need moving or weep after a bit of movement, new set of 4x 20mm x 2.5mm o rings sorts them out.
Louis
I Love Ed Sheeran
I've a set of those connectors i can pull off the matrix if needs be.
Check my thread for routing the silicone hoses.
BashRacing
Here's the bleed port on the thermostat housing,
When you have the new pipes on, remove the 10mm bolt fill with coolant and then start and run it until coolant flows out, bolt back in and test drive up to temp and re check level.
