That’s a lot of water coming out mate! No coolant pipes at the back of the engine except for heater matrix. Can’t distinguish which side it’s coming from, but could stat housing, heater pipes or water pump.
Header tank is in that area as well mateArgghhh
Straightforward enough, some of the pipes are a pita to get off but if you don’t care about keeping them can just cut them.
Has anything sharp been rubbing on that? or even if it was a small hole would the pressure then make it look so much worse?
Good luck getting it fixed in time.
How do you get these clips off the heater matrix pipes? Is this the PITA aspect of it?View attachment 1742347
Set of snips or careful cut with a dremel.How do you get these clips off the heater matrix pipes? Is this the PITA aspect of it?View attachment 1742347
You don’t remove the rings, the pipes unclip. It’s pretty straight forward once you’ve figured it out. Very much like the fittings on the carbon canister pipe that goes to the inlet.How do you get these clips off the heater matrix pipes? Is this the PITA aspect of it?View attachment 1742347
