Yay, another problem!
Advikaz
Went to get my tyre replaced this morning.
Got home and noticed water pouring out of the car and steaming from the bay.
Just about to jack it up and take a look.
Thoughts ?
  • IMG_4854.mov
    17 MB
NorthloopCup
That’s a lot of water coming out mate! No coolant pipes at the back of the engine except for heater matrix. Can’t distinguish which side it’s coming from, but could stat housing, heater pipes or water pump.
Advikaz
botfch
  Clio 182
Straightforward enough, some of the pipes are a pita to get off but if you don’t care about keeping them can just cut them.
Colin-S
  172 Cup
Has anything sharp been rubbing on that? or even if it was a small hole would the pressure then make it look so much worse?
Good luck getting it fixed in time.
BashRacing
Here's the bleed port on the thermostat housing,
When you have the new pipes on, remove the 10mm bolt fill with coolant and then start and run it until coolant flows out, bolt back in and test drive up to temp and re check level.
Brigsy
  T.Turbo
You don’t remove the rings, the pipes unclip. It’s pretty straight forward once you’ve figured it out. Very much like the fittings on the carbon canister pipe that goes to the inlet.
Need to chop the oem clips off for silicone hoses. Mine are jubilee clipped onto the original fittings.
