Cambelt timing tools
Panza
  Clio 182
I’m going to be doing my belt, pump etc soon and I’ve read quite a lot and watched some videos and seen a mix between people saying only use genuine tools and some saying it’s fine to use the knock off ones and wanted see what you guys thought, genuine are so expensive for something I’m going to use probably once and I don’t know anyone who has one and the knock are so much cheaper for what looks like does the same job, thoughts ?
Matt Cup
  Iceberg 172 Cup
Try and get genuine if you can. I managed to pick a complete used set up for not that much.
Panza
  Clio 182
Just out of interest what’s the reason for it obviously I know the genuine is 100% right but does anyone know if the laser ones are actually not right I don’t understand what the difference is?
Cheers lads
Panza
  Clio 182
I find this quite important when I get my belts done
Can appreciate this, it’s just I wanted to know if it’s the same with the laser tools or it’s just people being funny with it because it’s not a genuine tool, snap on make 100% right spanner’s but so do Halfords advanced for a quarter of the cost. That was my point and question
R3k1355
Aren't the laser tools known for not being fully accurate or bending? People end up with the timing out, which kind of defeats their point.
BashRacing
I have a Genuine and none Genuine pulley locking tool, they're identical apart from the pulleys move when undoing the bolts on the copy.
TheBandit
  Monaco172, Green1.2
My understanding is these engines are quite sensitive to timing, I personally wouldn't risk it as it will be wrong for years after the fact. Not seen any 'good' reviews over the years on being on the forum but happy to be told otherwise
Panza
  Clio 182
I appreciate everyone’s reply’s and input didn’t want come across and being a t**t to anyone just wanted to genuinely hear some good advice and reasons I’ve spoke to a lot of people today and I’ve heard biggest problem is people use the cheap ones incorrectly they use them to torque the pulleys back on but if you have the front pulley locking tool on properly like you’re supposed to it takes pressure of the MOT 1496
Only other option is to keep an eye out for any 2nd hand genuine one cheaper but I can’t find a genuine set for less than £280
Brigsy
  T.Turbo
Oem is always the best option, the crank locking pin is strong tool steel and can be used to undo and torque the crank pulley bolt. Also the setting tool fits well in the cam slots.
On the other hand, if the aftermarket cam pulley lock is good and holds as good as oem, the cheaper setting tool should work ok. As you say its used to set the cams, not hold them.
DaveL485
  21T, 9T, Meglio, V6
I've had an aftermarket set for about 10 years and never had an issue, as long as you use it properly and dont stress the horseshoe. You need the pulley lock bits.
S24NRC
  R27 Meglio
Timed an engine up absolutley bob on with a none genuine kit. Make sure the horseshoe is pretty substantial and dont rely on it for holding the pulleys and you will be fine.
