172 Cup pulling to left
172CupHGA
  Clio 172 Cup
Hi,
My 172 Cup pulls to the left. I have had it aligned 4 times and the problem persists. All suspension components are straight, tight, and there are no knocks or bangs. Tires are less than a year old. No accidents or kerb strikes.
I have three theories and was wondering if anyone else has had similar issue:
1. ARB bushes - these are cracked and need replacement.
2. Play in steering rack - A garage told me there is a minimal amount of play in the steering rack itself. I cannot replicate this on my mini-ramps.
3. Poor alignment - I don't think this is the case as I have used 4 different centres and the car always reverts to pulling to the left.
Has anyone else had a similar issue and can advise on the symptoms of worn ARB bushes and rack?
Thanks.
172CupHGA
  Clio 172 Cup
Thanks for the replies. The car has been gone over multiple times and no obvious worn or knocking parts. The springs , dampers, and top mounts were all replaced 3 months ago and the calipers rebuilt in the last month. These things needed doing anyway but have not stopped the car pulling.
Sounds like start with the bushes and work up to rack if they don't cure it.
Filters
Wales - South
Do you have the alignment print outs? If so, post them up.
My guess is probably rear beam. There never exactly set square and as they're non adjustable without shims - it's normally a culprit.
Will throw the thrust angle out - which affects steer ahead - making the car pull one way.
Rack bushes would make it feel like it was pulling from one side to the other - wouldn't just make it pull one way.
ARB, doubtful.
Try describing how it pulls left. Is it only under load/acceleration? Does it pull back to the right under braking?
172CupHGA
  Clio 172 Cup
ARB, doubtful.
The pull is slightly more pronounced under acceleration but not by much. The arc is fairly consistent. The car needs constant right input to keep it pointing down the road.
Shrab86
  Clio 172
Try checking the bottom ball joint holes. Mines were elongated. Had it in bits loads and that’s what it turned out to be
MLB
When has it had the rear shocks replaced last? That really affected the handling on mine, even just going down the motorway it couldn't keep a straight line.
RallyXmad
ClioSport Trader
  Cobra'd 172 Cup
I do motorsport alignments (and done a fair few Clios) for a living and the 2 most common problems I've found when people set up cars are that they don't use ballast to simulate driver / passenger weight when aligning, and using steering wheel clamps to hold the wheel in place when adjusting, instead of re-centring the wheel after each adjustment.
Everyone in this industry has their own opinion on how to do things and why, but I've found both of these do make a difference to the accuracy of setting a car up.
If your car has been set up with ballast and without a steering wheel clamp then thrust angle is the most likely, but would need to see alignment sheet to confirm.
172CupHGA
  Clio 172 Cup
Sorry, can't find any alignment printouts atm.
Replaced the steering rack and this has made an improvement but the problem persists.
I still have play in the top mounts, even though I had OE replacements fitted in the summer. I have noticed that the passenger side top mount (the side with the play) sits about 1 cm prouder than the driver's side. This is despite the same number of threads showing. What could cause this? A poorly seated cup?
Matt Cup
  Iceberg 172 Cup
Are you sure all the bits of the top mounts are there and in the right order?
Matt Cup
  Iceberg 172 Cup
I’ll be honest it’s been a while since I replaced mine. I’m sure someone else can chime in.
  Renault Kardian
Hi,
Thanks.
That sort of constant pull is almost always tyre related. Swap the front tyres left to right and see if the pull changes, radial pull will not show on an alignment sheet and can happen even with fairly new tyres.
Worn ARB bushes usually cause knocks or vague feel under load, not a steady pull. Rack wear shows as a dead spot around centre, not a bias to one side. Also worth checking for a slightly dragging brake on the left and that the subframe is properly centred.
172CupHGA
  Clio 172 Cup
That's a really interesting point - the issue did arise about the time I had 4 PS3s fitted last year. I'll swap the fronts tomorrow and see what difference it makes.
172CupHGA
  Clio 172 Cup
Top mounts appear to be the problem. Both sides fitted in the summer using OE parts. Both built up identically. But play in the passenger side, to the degree that you can rotate the spring within the shock when car is jacked up. Appears that the top mount cups may be different thicknesses. Has anyone seen this before?
172CupHGA
  Clio 172 Cup
Still got the issue. Quick recap on work done in last 3 months: 4 standard Cup shocks and springs, new SNR top mounts, powerflex front ARB bushes, powerflex steering rack bushes, reconditioned steering rack, powerflex rear beam bushes.
Took the car for alignment today and got these results. The caster looks odd and I assume is what is driving the arc to the left. What could have caused this imbalance?
get_attachment_url
cp1991
  clio 197
Did you rotate the tyres around? I’ve had a car pull drastically and ended up being a tyre.
Also if all the suspension checks out maybe a slightly sticking front caliper
Greeny.
  440i + 182
My mate also had issues with a dodgy tyre causing this exactly issue, can’t see it being the rear beam as they all came like that from the factory…
Filters
Wales - South
Caster angle isn't going to be helping much, essentially your passenger front wheel is sitting slightly further back in the arch than your drivers side.
So I'd be checking top mounts and bottoms arms. Standard caster angle is around 3.0degrees.
RallyXmad
ClioSport Trader
  Cobra'd 172 Cup
Alignment doesn't look horrendous, I've seen a lot worse.
How old are the shocks? Could be a dead one.
You mentioned previously about thickness of the top mounts. Have you measured the ride height of the car on a flat surface? Easy way to do it is arch to floor. If there is a drastic difference on 1 corner then the issue could be there. Make sure tyre pressures are set before you do this
  '10 Clio200
This might sound stupid but, have you tried swapping the springs left to right?
It can be done very quickly, just swap the struts.
I know Renault had pull issues circa 2004 with the transition to the 182 and it was deemed to spring seating/conformity... Maybe you have a dodgy spring/spring seat (damper).
172CupHGA
  Clio 172 Cup
Tried all suggestions and still got the issue. Looking for lower arms for a 172 Cup - anyone know of any for sale please?
