imprezaworks
  Mk5 Golf GTI :)
Got it ready to sell, maybe....
Matt Cup
  Iceberg 172 Cup
I'm putting the blame squarely on it being at a garage at some point and it being removed then! I wouldn't have removed it and left it off.... :)
Your slam panel has been off and replaced as I am sure I remember it missing the Renault stickers.
Darren S
Out with the shitty Pipercross foam air filter and in with the Ramair.
Found it much easier to fit with the battery temporarily removed (probably not essential) - but glad I did as the right-side battery retainer clip was very loose.
Me being me and finding a rattle-can of Hammerite knocking about - I had to tart-up the two battery brackets and airbox support to look a bit nicer at least.
A bit of wire-brushing and wipe down for these...
Got them looking better after a few light coats.
End result...
MLB
End result...
That looks very tidy!
helpimonfire
  '06 197
Got around to fitting the rear GAZ Golds today, I know you need to fettle the inner arch/body on the NSR but holy s**t I didn't realise how much you need to beat the living s**t out of it.
helpimonfire
  '06 197
Is that because they are coil on shock design you had to get the hammer out?
Yeah rather than the old divorced shock and spring setup, the GAZ Golds are a true coilover. OSR has enough space between the spring and body that you could house a small CS.net forum member.
cat171
I went and got the 172 out last night. I haven't driven it in about six weeks. It has just touched 91k and the right indicator that didn't work (so I thought it was the UCH) has sorted itself out. Good car!!
Clio_fool
Went to swap the door handles over on my sons merc since the replacement doors have a chrome strip on the handles and the body shop didn't paint them when they did the doors. But...
f**king Germans have to go changing s**t for no apparent reason 🙄. Ffs.
E11OOT
  182/V6/R27/R26R
Busy times for the Jean Ragnotti:
  • Cambelt + Dephaser + Pulleys + Crank Pulley
  • Aux Belt + Tensioners etc.
  • Sump Pan Gasket
  • Gearbox Selector Leak
  • Engine + Gearbox Fluid Changes
  • Disc & Pads All Around
  • Plugs
  • New Wheel + Tires + Spacers
  • Studs
  • Engine Mount + Gearbox Mount
  • Bunch of Cleaning etc.
Just want to put a new clutch in the car and then she should be good for a while!
CrippsCorner
  A250 EbAMG
Ordered a spoiler from AliExpress to which the seller has contacted me saying it will leave a gap between it and the roof and will I be happy with that 🤔
PerthRS
  Clio 182 CUP
  • Sump Pan Gasket
  • Plugs
  • Studs
To resolve selector leak. Did you pull the box out or buy one of those kits that allow the box to stay in situ?
