Rojer's 200T
Wheel bolts arrived so wheels on. It must have some rear spacers I didn't know about as it shouldn't be that tight lol. Good job I didn't get 7.5j wheels. I'm sure the rear arches will self clear or ill get the hammer out. Even going round the block, you can tell the AR1s are serious. A lot more noise on the road.
View attachment 1797825View attachment 1797826View attachment 1797827View attachment 1797828
Look decent fitment wise. But that rear wheel not sitting in the centre of the arch makes my teeth itch. Probably a trick of the lens so don’t panic Roj
I've never had arches self clear.... i've had arches destroy expensive tyres before!
Have you got a rounders bat or a jack handle wrapped in something?
It only rubs if I go over a speed bump a bit quick, it was fine down my local bumpy road. Bedford is flat so hopefully it will be fine. I can massage it with the jack handle if needs be.
I'm considering taking the spacers out, but I would need some stub axle bolts. Anyone have any suggestions on what I can use?
