Rojer
Always race mode for me. Does the 200 have that?
ESP kills the rears in no time.
Yeah same
Yea but they (Schirmer) are running very different brake setups with adjustable bias. I do wonder if these things become internet folk law, originally the rear pads weren’t available in whatever new grade of pad is popular etc.You don't need such an aggressive rear pad on them. Pretty much everyone runs a similar setup inc all the Schirmer builds. Milder rear pad just seems to be the go to as they are still front bias
Are you using this every day too Rojer?Yeah same
I feel insulted that you asked that!Did you have traction & esp turned on?
I don't get why you're all pissing and moaning
Different pads act different in different cars and different driving styles
Get it sent you big jessy
Your rear brakes look like they haven't worked since 2001.I don't get why you're all pissing and moaning
They seem like such a good all rounder!
If you need any machining doing pm me and I'll see if I can help outInteresting cheers mate, ill have a look into it.
Ill stick a post up about therears on my thread. Ive been trying to mock something up, but i feel it will soon excede my backyard engineering skills![]()
Schirmer cars don't have adjustable bias, they also run the same setup brakes that mine had pretty much.Yea but they (Schirmer) are running very different brake setups with adjustable bias. I do wonder if these things become internet folk law, originally the rear pads weren’t available in whatever new grade of pad is popular etc.
Running the same pad front and rear, as long as you can get the rears hot enough (which on most things you can) gives correct bias, running the most rear bias you can gives you the shortest stopping distances.
they do naff all on the rears mine did over 100kYour rear brakes look like they haven't worked since 2001.
They do adjustable bias via the MK60 calibration.Schirmer cars don't have adjustable bias, they also run the same setup brakes that mine had pretty much.
I had APs with St45s and stock rears, wasn't great, PFZ on the rear was better then RSL29s again were better on stock rears. Same front pads again for a while with F80 rears and PFZ then RST3/RSL29s in its final from and was super balanced under brakes. Drexler helped a lot with that as well mind you.
I wouldn't know, you've stopped coming to CSFthey do naff all on the rears mine did over 100k
I only missed this year…!I wouldn't know, you've stopped coming to CSF![]()
Depends where it is next year….It has been logged.
These are my RC5's after roughly 12 track days and several thousand road miles.Bought in 2018 & apart from a brief try of some mintex pads only just changed.
But I am constantly told I don't brake hard enough by @M.C..
New pads, I hope they do the trick. Still waiting for my lines to be sorted.
