Digi Dash
Struggler
Car  Ph1 track 172
Has anyone toyed about with wiring a digital dash?
Currently running a GEN90 ECU on my track car and would love an digital display but no idea where to start with the wiring.
Also if I could get rid of all the lights on my dash it would be great!
I ran an Aim MXL dash in my PH1 with a SCS delta. 2 wires for CAN iirc and then ran seperate sensors for it.
Never bothered with Speedo as it was a race car but they did a GPS for it so could easily have used that for speed and LapTimer
As above you will get most of the data via can for a digi dash, if the dash will support your ecu stream you might get a bit more data than generic obd protocol.
Stuff like tell tale lights and fuel level will need wiring separately.
oh yeah I never sorted fuel gauge just used the old dash and plugged that in when needing to check 😂
Speedo wise, might be possible to wire in oem speed sensor on box or hall sensor on abs ring to ecu.
Are these can wires going into the clocks?
There was me thinking (hoping) that it was just a case of characterising the wires into the back of the clocks and adapting them to a new, digital set of clocks.
