Clio seat slide rails - fix
Car  2004 Clio 172
Hi,
I bought a Clio 172 (2004) earlier this year. Mechanically it's been great, but the interior lets it down a little bit.
I was at a trackday this week (Snetterton was amazing!) and when I went to adjust the passenger seat further back, I noticed that it no longer locks into place after adjusting it.
Are the seat rails replaceable on their own, or would I need to replace the entire seat? Has anyone had this issue before?
Thanks all :)
Replaceable on their own, four bolts under the car to unbolt the whole seat, then the seat rail unbolts from the seat. Think you need to disconnect the battery and then the wiring to the seat for the airbags as well if they're the original seats.
I thought I had the link saved, it's on here somewhere, but I can't find it quickly, but someone linked to aftermarket ones.
Otherwise you might be able to get some off any same age Clio off a scrappy (believe they're all the same).
Think they're called seat runners.
Thanks, that was a super fast repsonse.
I'll go get my toolset out now :)
No worries!
It's not bad, might need to get a wiggly connector or extension on for the bolts next to the exhaust and soak them in some penetrating fluid as they're exposed to the elements. The bolts near the door are behind a rubber grommet.
I believe mine were hard to adjust and there's a plastic piece in the slider that had gone brittle and blocked the locking mechanism. But it's also been years since I changed my seats so I might be talking s**t😂
When I bought my 172 Cup the drivers seat wouldn't slide forward without a good yanking. I found that there was a piece of yellow plastic that wedged in the runner on the gearstick side. That could have been the plastic piece mentioned above. I removed it and gave everything a good spray with WD-you know what before working the seat back and forward to make it move freely again. My runner are also worn but the seat does work as it should now.
