182 decat sounds
  laguna coupe
what would a 182 sound like with a standard zorst and get the cat taken of and the silencer so its just got the back bock left on it vids welcome
Tom
  i3
Depends if you like it, ive done it and i think it sounds terrible.
But it cost £1.46 and its quicker.
  Mondeo STTDCI
Yup its not a particularly pretty sounding car. But certainly opens up more.
  K20 EG Hatch
thats what u got, standard exhaust with a yozzasport decat.
Sounds rough as f**k when its cold lol but once warmed dont sound much difference to standard, deffinately a bit beefier under load and sort of "tinny" in a funny way.
Tom
  i3
Actually im not being sarcastic.
£1.46 gets you a metre of mild steel 60mm pipe. which is what i used.
  Lionel Richie
^if you are a pikey that can't weld ;)
out of interest mr TBR how did you create the knuckle flange? (can i have a sticker)
Tom
  i3
Yes you can have a sticker.
The decat is based on the original cat. its very easy to do.
*Buy Pipe (60mm is best)
*Remove cat/center box.
*Cut the flange off the cat from the manifold end.
*Slot pipe into flange (may need to be grinded flush first)
*Tack weld pipe to flange
*Bend pipe slightly (i used heat and a bar)
*Weld flange properly
*Remove detachable bend section before back box
*Fit pipe to car (For the rear connection the pipe can have a slit cut in it for bracket use but i just welded it on)
Drive off.
Total cost
Pipe £1.46
Welding £depends
Skill £priceless
And all i have to do to refit the cat is reweld the flange back on.
Easy.
