brake fluid
Last night was parked on a hill and my handbrake light and stop light came on am i correct in saying that it is the brake fluid or not if it is how much is suspose to be in there There is a little plasic circle inside is it supose to be over flowing that . It was a pain to find not in the book :)
cheers matt
Ok will do in the morning but need to drive to Southampton about 65 miles each way in the morning will it be ok just for tomorrow and can do it when i get back or is there something seriously wrong
cheers matt
it should be fine if its only just started coming on, but get it looked at ASAP and don't do a track day on it!
That's good its only come on once last night when i was on a very steep hill and hasn't since so will look at it when i get back cheers fred
I checked my brake pad by looking though the wheel and all the outside pads look fine. Does anyone think that the inside pad will be more worn than the outside ones just haven't got round to taking the wheel off i read the post by Dave about the 172/182 being low on the first service so that would mean that it wasn't topped up fully from new then only a little bit of wear would bring the light on is this right
cheer matt:D
They cna wear more on one side if the calipers sliders are stuck as they can be.
The low fluid level is supposed to indicate when new pads are needed when the levels low pads are worn. and the warning light goes off.
Cheers Will get the wheels of on the weekend and have a look.
There looks to be load of the pad left when i look through the wheel and i have only done 8500 on them
