Depends what type you get ones with dust seals are just like normal calipers none dust sealed you might need to clean up ever year you might not need to do it for years buit parts are dirct cheap anyway.Are the 4-pots the ones you have to clean out once in a while due to no dust shield things or something??
Because Renault wanted to reduce the costs? Why do Team Think + others run 4 pots ?ask yourself this, if a mk2 clio NEEDS 4pots, why didn't the cup racers have them??
Each to there own I miss my 4 pots I'd never had said they were overkill they never faded never had any real wear on the disk and pads and were easy to use no squeeks etc.4pots are overkill on a light little clio
There are very expensive I'd stick with ds2500's and new disk lines etc 4 pots are great but pricy for most kits out there are they worth the money debatable. For most driving including most track work ds2500's are best value realy.Cheers for the replies,
Am swaying towards the four pot conversion.
Can just about spread my budget to suit, so why not.
You can never had to much braking IMO.wilwoods are a bit over kill for everyday driving, upratieddisks, pads and lines are sufficent.
edde aka "the lock up king"
if you have ever spoken to any of the Clio cup teams or have ever been in the passenger seat in one you would realise that the calipers that are fitted to the Clio are Moore than enough you just need a good set of brake pad's and disk's
enduro racing edde, thats why
Why do other Clio race teams use 4 pots then?
Don't get me wrong there great stock but they have there weeknesses IMO.
i know that Fred and yozz are trying to get the cup down to 1000kg i am not shore what the weight of the Clio cup's are but should have thought that its about the weight that Fred and yozz are aiming forimo 4pots would be an advantage even for hard road use let alone track but cost wise its hard to justify when the standard kit is pretty good.
As a matter of interest what are the weights of a FF182, the Yozzasport car and the cup racers?
yozz doesnt look that old .we're only getting the weight of the car down because yoz is getting old and fat![]()
there are a few up for sale on the web around £9000 which is a bargain as the gear boxes are £7000 .maybe soon, who knows!
