G galla Nov 25, 2006 #1 can you check your cpu temperature in windows. i know you can in the bios but can you do it without having to shut down and go into the bios cheers
T Tiger Nov 25, 2006 #3 get a program called everest, it tells you everything you need to know about your pc, great program!!
lewisniven Car Golf GTI PP Mk7 Nov 25, 2006 #4 MBM5 is good too, just sits in the system tray and tells u what u need to know without getting in the way.
seb ClioSport Club Member Car bac50 iirc Nov 25, 2006 #5 how do i find out what motherboard i have on set up? can i type anything into my computer to find this out?
seb ClioSport Club Member Car bac50 iirc Nov 25, 2006 #6 sorted that out^^^ what is a good cpu temperature?
A Adam K Car Fabia vRS Nov 25, 2006 #7 seb said: sorted that out^^^ what is a good cpu temperature? Click to expand... about 40 to 50 degrees idle. really depends what processor, what fan, and what cooling compounds u are using.
lewisniven Car Golf GTI PP Mk7 Nov 26, 2006 #8 p4's u shud be looking at about 40-45 idle, 55-60 max, depending on ur overclock etc. Prescott core P4's run hotter than the rest too. Athlons shud be about 35-40 idle and about 50 maxed out, lik I say tho, againdepends on core and overclock. Ive got a P4 Prescott 2.8ghz overclocked to a stable 3.6ghz and thats 45 idle and 60 maxed out.
