Herdie- They will hopefully, had big problems with overheating,bothat Oulton last year and on both my 'ring trips.
Paul J- I could cut these down so that they sit flush (what i was aiming for) but i like them like this. But you can get ones with a smaller diameter ducting, mine is 89mm id, there are others and also different colour options on the inlet as well.
Is that why every race/rally/track car worth there weight has them? If you are woried about high speed lift on a Clio then im afraid you know nothing about aerodynamics!!!!! And are highly optimistic of your cars capabilities!!!!!!!!!!!!
im not sure whether they are too obvious for me, i dont mind having the CAF cut into the lower grill, but im not sure about those. sure they will do alot of good though, have you tried the hair dryer trick? )ie put the hair dryer by the cold air feed and feel how much air comes through at the other end)
