How Low?
Car  RenaultSport Clio 172 CUP
How low to go on H&R's for a cup, btw there are speed bumps and roads aint so great someplaces i go :p soo ???
i dont have a cup, and i dont have H&R's, but my FK's are set to max on the back and pretty damn low on the front and round here where we have lots and lots and lots of speedbumps its absolutely fine if you dont go stupid speeds over them... crappy lanes havent been a problem yet either
ok, well im guessing i will get a local garage to do it, so what would i need to tell them? any settings i'm best to stick to? or height differences between the back and front?
good choice, mine are wound down fully at the back, and low at the front..... The front should always be lower than the rear when looking side on at the car NOT level
The height depends on what you use the car for really. If you do alot B road thrashing i'd only say 30mm as this gives you plenty of spring travel to soak up the bumps. Mine is fine for A roads etc, but can get a wee bit lairy down some B roads...... its set up more for looks tbh!
Easy to adjust mate just jack it up and away u go..
Just make sure u set them higher than this before dropping t back down as this was not far from the deck
yes, pice of piss matey, they just have two collars (on the front) one adjusts the height,you use a C spanner to adjust it, then when your done, use the other collar to 'lock' it
i adjust mine on thread left on the coilover unit, then double check with the wheels on (tape measure jobbie)
^^^^***doh*** beat me to it, yeah i remember doin that first time too!!! trail and error upon first fitment
height is insignificant with coils. make sure the caster/camber and cornerweights are set up proprly.
Mines runnin 1.75neg cam with RS shims. 1deg toe in at the bak.
it's low. But perfect. Feels incredible.
they need setting up properly tom as your camber is gonna be out,the top bolt hole is elongated so they can be laser adjusted
maybe on a smooth track but not on bumpy roads cause theres no give,had mine profesionally setup and its lowered about 40mil
hillpower fitted them and he gets someone to laser line it then for the camber,he's quite busy at the min i think but if your desperate to have them fitted you could always have the camber setup at a later date
H&R's dont have this, you will need camber correction bolts ;)
