Second hand off here Pick them up on SundayWhereabouts are you getting your H&R's from?
height is insignificant with coils. make sure the caster/camber and cornerweights are set up proprly.
Mines runnin 1.75neg cam with RS shims. 1deg toe in at the bak.
it's low. But perfect. Feels incredible.
they need setting up properly tom as your camber is gonna be out,the top bolt hole is elongated so they can be laser adjusted
H&R's dont have this, you will need camber correction bolts
Bridgnorth tyre centre do tracking.
I'll fit them for £100 lol
:quiet:
i think you'll find the 2nd hole is elongated,no need for camber bolts,and i've seen 3 different sets of h&r's and they were all the same
