I would, but my street has cars either side and with the snow etc I dont fancy pushing it, then if someone comes down the road im screwed lol.
Will it be ok once its started up?
Imobaliser???
how olds the battery? cold/winter kills batterys
Imobaliser???
not that m8 as it would not have started ................ my idea now would be the fuel problem . did anything light up on your displays ?
Could be the crank sensor.
Know its too late now, but if your car has a cat on it DON"T bump start it as this can cause damage to the cat. Better off with a jump off another car
I think I would have noticed a cat on the car lol...seriously, whats a cat?
Erm the smoke is a grey colour, looks abit like steam, fingers crossed it is just the condensation.
he was on about damaging the catalytic converter
Aye, what kully said, basically iirc, when you bump start a car unburnt fuel is pushed through the system and into the catalytic converter (not poor Mrs Smiths ginger tom) this unburnt fuel can then cause damage and you end up needing a new cat.
The bad smell would be from the cat , but it's sometimes caused by plugs or leads breaking down .
the problem at the moment imo is the battery not keeping it's charge , the weather is damp atm so , try again in dry conditions .
No havnt changed them, I have no moneyI cant afford this.
£100 for a CAT, how much to fit do you think kully?
its probably not your cat .....40 quid fitting i'd say ..... get it checked properly if you're not sure m8....battery and leads/plugs 1st
Change your fuses, its usually the most simple things that get overlooked!
