Vista style on XP?
there is the so called hidden black theme for XP called 'Royal Noir'.
I use it and like it!
The is also Royale Zune but I havent a clue whats thats like, think its black and orange.
Thats not bad
Right I have a problem guys... I downloaded this..
http://www.istartedsomething.com/20061029/royale-noir/
Extracted it with WinRAR to correct path...
c:\windows\resources\themes\royale noir
double click on Luna like it says and the theme comes up in the display settings on appearance, choose royale noir, apply + ok it etc, it works, nice black theme, very sleek just what I wanted
BUT - I restart or turn off the computer and it's gone and instead gone back to windows classic theme, which is boring. How do I go about making it permanent on my computer so it's there when I switch on/restart.
I have a fix for this to stop it reverting back to the claasic theme.
I will post it up in a sec after double checking it works!
yep fixed it!!!
Right in order to get this scheme to work do the following......
First go into C:\WINDOWS\Resources\Themes.
Next make a new folder called Luna2.
Then extract the all files in the royale theme that was in that rar file to the above folder.
Then all you need to do is rename the Luna (windows visual style file) to Luna2 and you should find it each time in the appearance settings and it should not revert back to the old "classic style"
Let me now if this helps or not!
Richy
