Damn Renault - Wont Turn Off Airbags
  RS Clio 200
the slags wont turn mine off even though im putting in buckets with road legal harnesses.
time to call the next dealer
  RS Clio 200
yeh thats what i thought, although they said they are not allowed.
not giving up yet thogh
  RS Clio 200
hmmm dont think i got any specialists round my way. just dealers and franchises.
shall have to have a look.
Yosemite Sam
  Whichever has fuel
w**kers mate it is not illegal to have no airbags so they should do this
They won't do it because when you crash and the airbag doesn't go off and the seatbelt pre tensioners don't work, you can sue them for turning it off. So hardly w*nkers are they, more like business people that don't fancy being sued.
  RS Clio 200
there wont be any seat belts or pretensioners. just road legal harnesses
I don't see what your problem is your asking them to turn on standard safety spec items I would refuse to do it as well.
  Clio 182
Have you put the buckets and harnesses in? or is it something you plan to do? who dont you put the seats and harnesses in first then a garage might be more inclined to turn them off. They might turn the airbags off then you never fit the seats or harnesses or drive out the garage and have an accident straight away.
  RS Clio 200
ud refuse to do it even though the seats are not there so there are no bags to go off?
  Carrera 4S. Clio 172. M5
If you have removed the airbags and the seatbelt restraints, the module is under the dash behind the ashtray location and the fuses are clearly marked.
If you are not sure about which module it is, the clue is the yellow wiring conduit that is used on all SRS related wiring.
If you haven't advised your insurers, I would strongly recommend you do so.
Hope this helps
  RS Clio 200
Hope this helps
will removing that solve the light on dash thing though?
Insurance dont know, but will on monday. They have all my mods listed, even ones i have not yet got round to doing. They dont charge me extra which is nice of them.
  Clio 172 MK II
why you don`t just put resistor on airbag wires?
that will turn the light off
and you can do the same with seatbelt pre tensioners aslo
resitors should be 3,3 ohms
i did that in mine car and everything is working fine :)
The warning light is powered up from the module so removing it will kill the light.
  RenaultSport clio 172 mk2
Won't that disable to steering wheel airbag as well?
And what about the passenger side dashboard airbag?
  RS Clio 200
steering wheel is being replaced soon anyway so thats irrelevent, and the passenger side you can just argue that its not needed as the only belts in the car you can wear now are the harnesses. ure going nowhere basically, so no need for the airbags
Yep.
What happnes when you go put the stock ones back in what happens if you go crash not worth the hastle for a garage for no huge gains.
  CTR--VX220D
I dont see what the issue is here.
Do what I did and cover up the recesses in the display stopping the light to flash through to the display - job done!
I even wrote a guide
The resistors in the steering wheel didnt work for me so did the above when I completely stripped out the 172.
