Cold air feed to standard airbox
Car  182 Cup
What size of pipe do I need to run one down to the bottom grill? I imagine a 2 metre odd one to trim down to proper length but what diameter does the pipe itself need to be?
about 105mm i think if u are connecting straight to the air feed or 50mm? porb ok for a air filter, im sure someone will now tell ya buddy theres some real EGG heads on here lol, all gd lads :)
I'm assuming you mean a cold air feed to the front hole in the standard airbox ? Its oval and measures 80mm x 62mm so a 70mm caf should be fine .The second hole underneath the airbox measures 80mm x 54mm .
would seem alot of trouble , i like the idea of making an induction kit using the mk1 air box like len beach has ... looks cheap but very affective
