Cold air feed to standard airbox
  182 Cup
What size of pipe do I need to run one down to the bottom grill? I imagine a 2 metre odd one to trim down to proper length but what diameter does the pipe itself need to be?
TeZ
  Non RS : (
about 105mm i think if u are connecting straight to the air feed or 50mm? porb ok for a air filter, im sure someone will now tell ya buddy theres some real EGG heads on here lol, all gd lads :)
MRBILLYUK
  FF Jeden Osiem Dwa
I'm assuming you mean a cold air feed to the front hole in the standard airbox ? Its oval and measures 80mm x 62mm so a 70mm caf should be fine .The second hole underneath the airbox measures 80mm x 54mm .
would seem alot of trouble , i like the idea of making an induction kit using the mk1 air box like len beach has ... looks cheap but very affective
  Milltek'd 182
what benifits are there to the mk1 airbox? id assume renault would have only improved it for the mk2 lol :eek:
