really silly qustions
Car  53 Clio's & counting
1: why do u guys call ph1 172s ph quick?
2: Do u think 5w 40 oil will be ok on high mileage?
3: How often should brake fluid be changed? (with vws its every 2yrs regardless of mileage-is this the same with ren?)
4:i have a blow just behind my rear box on the bend-typically my rear box is quite new,is it worth/can u replace just the centre section and if not what cat bk system could i get that wont drown out my ears?
5:why do smarties only have the answer?
cheers lol
i have a question too, what the hell does IIRC stand for, intelligent intergerlactic rally car?
1. The phase one is the quickest supposedly.
2. Should be.
3.Dunno.
4. As above.
5. Noone else lets you get high.
An IIRC stands for If I Recall Correctly.
If I Remember Correctly or If I Recall Correctly, arrrggh!! I'm torn between the two I think my heads going to explode!! :star:
Doesn't matter which one really, they both mean the same thing.
or DMWORTBMTST for short
1) There often very quick no idea who started the hase there quite a number of very quick ones there the most fun to drive as well.
2) Yep no problem its stock oil that. 10-40 is fine upto -20 degrees only need 5-40 ito protect down to -25. 5-40 will help protect more when cold though.
3) IMO every year if you driive hard with harder racing spec pads 2 years or so otherwise depends how and how much you drive. Also how good the fluid is your using.
Ktec do a stealthy exhaust.
I'm not sure what you mean by back box the joint which usualy fails in the one joining the back box to the pipe by the suspension rear axl.e It fails due to the fact it weight to much personally get it up on a ranmp and have the box welded on and an extra bracket welded up to hold the box better and its fine.
My wife just got home from work, she used the 172 today and just told me she lost her bottle against a DCI clio up to the 100mph mark, shamefull behaviour??!
I have a silly question: Why do some women squirt and others not? Baffles me, its quite annoying really, messy if anything?
