bmc induction bend size
hey i just got a bmc induction kit but it hasnt come with the 90* bend i need to fit it? any one know what size ill need and where i can get one fast I.E will halfords or any shop like that stock them?
What model number is the BMC mate? just measure the Dia. and that will be the size you need ;) Don't think halfrauds sell that type of item? Could be wrong... people like gasperformance or even venair will do a next day delivery. Failing that, are there any car mod shops close to you?
bmcf1a-cda70-130 just rang them and they said it wont fit my car even though i used there system to order it :s
my cars 80mm the filters 70mm ill need a tight (80mm) 90* with a straight then a pipe attatcher, going to a 90* that drops down to a 70mm to attatch to the filter. went to my local place and they said it would cost £95+VAT!!
what??? Cant you get a reducer pipe for much less than that?
If it was off their website for your car model then you can get a refund!
yeah but i need more then just a reducer i need 2 strates and 2 90* bend one side 80mm one side 70. yeah they said i can have a refund but i hoped i could make it fit for under £50
you should be able to mate,i have a 1.6,made a few enquiries myself,a 90degree elbow which reduces from 90mm to 70mm then a 45 degree chrome ducting tube and then connect the bmc to that,will come in at just over 50 :)
The BMCs are pretty much all universal kits, the filter is suitable for the engine but its up to you to sort out most of the connecting tubing. You need to cobble up something like this and don't forget about the crankcase breather.
