What makes you think its the resistor pack, whats actually up with the air con, ie can you hear the compressor kicking in or is it just not cold enough?
Take the drivers side scuttle panel off, one screw clip and one holding it on the wing, pull it out. Then you'll see it and the fan etc...
http://i106.photobucket.com/albums/m271/BrianR_04/DSCF2553.jpg
http://i106.photobucket.com/albums/m271/BrianR_04/DSCF2552.jpg
Brians Piccies not mine.
Christ thats a mess! Water ingress?
You would have thought Reno would have placed such a part, which isn't exactly cheap brand new, in a place where water couldn't get to it.
lol, in a mk1 punto thats where the ecu is!!!!!
Where about on the 172's are the drainage areas? I would like to check it to see if any leaves have clogged it up.
