2003 clio 172 sport dash tweeters
  clio sport 172
hey every one , i knoiw got to take dash out but is there any other way of getting to change tweeters, or if got to do dash how do i get it out is it easy and how hard is it to put back in ?? has any one done it before , or can some one give me pics of how to do it please thanks chris.
oh an has any one ever put a a amped wire in to the door pannel , and how do you do it ??? can any one help
ChrisR
I took the top dash off my mk1 172 the other week, had been dreading it but it took no time at all, was dead easy. The ph2 I believe just has some more screws by the airbag I think. Fubar has a guide for the ph1, don't think your model is too dissimilar.
yeah watch the passengers side airbag when you take the dash off. there are 4 screws holding it in take those out and all should be fine. do not unplug the airbag tho ;)
i also need to know about putting new wires into the door
  Polo Bluemotion
Ive been thru the same problems guys. in the end i went for a set of in phase components,for two reasons; if you twist the standard grill off,the in phase tweeters just slot rite in+look factory done.(ill post a pic!) and secondly because of the depth of the speaker, i would of preferred alpine type r's,but they wont fit without hacking the door away!!
Its very much possible (I did it!) to install a set of components/replace tweeters without taking the dash out!!! If you unscrew the tweeter grills,ull find that ur tweeter is offset to the grill quite alot due to the heating ducts.Just pop them out and unclip the plug.It takes a bit to wiggle out,but you can do it. Then cut the plug off the factory wiring(to allow room for your new tweeter). I dont know if all tweeters are made the same in component sets,but mine had the wires already attached to the tweeter. I fed the wires through the dash,(with a bit of help from a metal coat hanger!) I then aimed both wires over towards the passenger footwell. Obviously the right tweeter tooks neat under the steering column,round the back of the head unit and meets with the other. I fixed the cross overs by buying some velcro pads and sticking them onto the highest point i could reach behind the glovebox (to stop passengers kicking them!!) I had to super glue the velcro pad to the bulkhead because it wasnt gripping very well. I used velcro pads, so it would be easy to get at them or take them out if i needed to.
I got round wiring the door quite easily,i didnt take the door panel off.As u know the speaker grill just pops of,so i swapped the speakers round. Then cut into the wiring loom (not the cars,the alpine one!!)at the back of the head unit,then mounted the crossovers right up behind the glovebox. Doning it this way, does away with the need to get your cable from the door,to the car. Its not possible to feed it with the other cables (windows,mirrors etc) because its a form of plug.
Doing it this way gives a much more factory look. Hope this helps
  clio sport 172
so i can just unscret the tweeter off teh top fut the wir down for new on and put in place , d the com out ok or will they look dead afte woods, and ietehr like ofv th plug on head unit or can i cut teh wire just in side the door under by teh pedels and link on to there from my amp and then run up to the tweeter from the cross over ??
  Clio 182 (Black Beauty)
im not even that broad at talkin lol. i`ll hav fot try a bit harder int futur
  172 CUP
To get the wires into the door is quite simple, take the plug apart and use the space where the existing speaker wires go through. It's always a good idea to upgrade the cable as the standard stuff aint too good, especially if you are spending money on new speakers!
  clio sport 172
how you get the plu apart , you mean the one insie the door , and how ou get to the back of it , do you mean just pass the new wis throught .
oh and how do you unscrew t tweeter cove with out hav ing to take the dash out ???
  clio sport 172
so now got the cover off but how the hel do you get teh tweeter out from where it is and how is it fixed in looks like the dash will have to come out after all
  Audi TT 225
Took the dash off using Fubars guide and replaced them. If it is a phase 2 there will also be another 5? screws to remove it. These are found behind the airbag strips (4 behind the left 1 and I think 1 behind the right one). It then just slides off, it really is a piece of piss to take off/put back on and only takes a couple of mins once you know where all the screws are.
  clio sport 172
dose it just lift out then over the steering wheel , so is nice and easy to do , yer it a p2 , i know were all screwys are bit worred about moreing bits around the pass air bag thougth
