d/c battery for 20mins to discharge battery
unclip airbag from back of steering wheel,may need to turn 90 degrees to get to clips
remove airbag carefully
undo torx bolt in middle of steering wheel
unclip horn and airbag buttons
then remove wheel
as above you CANT adjust it... there one notch much wider so it can only be put on that way, any adjustment will need to be done on the track rod ends.. so you need to adjust the tracking....
