Steering wheel removal
DrR
  VW Golf GTD
How do i? Tried searching but everything is vague.
  172
d/c battery for 20mins to discharge battery
unclip airbag from back of steering wheel,may need to turn 90 degrees to get to clips
remove airbag carefully
undo torx bolt in middle of steering wheel
unclip horn and airbag buttons
then remove wheel
hardest bit is getting the airbag off, i used a bottle opener on my pocket knife to get mine off :cool:
will also need a torx 50 bit
DrR
  VW Golf GTD
Ok cool, i'll have a look, as it's not on straight!
  RenaultSport clio 172 mk2
The steering wheel centre has a notch in it, you can't adjust it. It will only go on one way.
Take it to someone that does tracking/wheel alignment if it's not sitting straight.
DrR
  VW Golf GTD
"unclip airbag from back of steering wheel,may need to turn 90 degrees to get to clips"
How which way are they ment to unclip?
  www.renparts.co.uk
as above you CANT adjust it... there one notch much wider so it can only be put on that way, any adjustment will need to be done on the track rod ends.. so you need to adjust the tracking....
