Gearbox Oil change! Do It!
Car  R35 GTR
Downchanges seem to slide in much better now!
Castrol Syntrax 75w-90 Gear Oil 4Litres semi-syn GL4/5 £37.95
Not cheap, but the gearchanges are much much smoother. Not given it any beans yet.
How do you change the oil on a 172/182 mate ?
Or more to the point, where is the drain plug and fill plug ?
Does the fill and drain plugs use any special square sockets ?
Do what i did, change the gearbox, now technically on my 4th one in 62k ;)
mate works for renault, get discounted services/less the labour etc... had my 'box oil changed a lot earlier than required by the stealers... cost less than buying the oil myself, and made absolutely NO difference!
there is a good guide in the guides section. But essentially its the same square 8mm bit for the sump plug.
I got a flexi funnel and jammed some pipe in the bottom to get it into the hole easily.
do you get the dirty great bang when you change up giving it beans?
Theres a good guide made by dan in the guides section. IMO it should be changed every 40k.
i'm always quite careful, but before i changed it i used to get a bang getting back on the gas, but the new bush completely stopped it. definately worth doing!
