LOCKED THE BOONNET :|
  16v Clio
CLOSED THE BONNET AND THE RELEASE LEVER FELL OFF WHEN I CLOSED IT
CANT GET IT OPEN NOW
ANY IDEAS ?
ONLY THING I CAN THINK OF IS GETTING IT ON A RAMP AND GETTING IT OPEN FROM THE BOTTOM :(
ANY IDEAS ?
Closed the bonnet and the release lever fell off when I closed it
Can't get it open now
Any Ideas?
Only Thing I can think of is getting it on a ramp and getting it open from the bottom :(
...Soz. Can't stand Caps :)
  clio mk2 p1 1.4 16v
yea ramp only way well easiest way thihnk about it no gaps from anywhere other than the underside soooo ramp it is unles you can crawl under it and poke ur arm or somthing up there
  172
how much of the handle came off?can you not cut back some of the black outer casing to it then use a set of pliers to pull the release cable?
  53 Clio's & counting
well my bonnet release handle (the one inside the car) pops off all the time,just push it back on if thats the one you mean mate
