Servicing Clio Dynamique?
ati
Car  Clio Dynamique
hello all
i just got my renault clio finally, i just had it serviced, replaced:
oil
plugs
filters
lights (3 bulbs)
windscreen wipers
breaks (pads and discs)
the only thing i havent replaced is the Fuel Filter ( how much does it cost? to get it fitted and is it vital, i dont know if it was replaced before or not)
they also checked the fluid levels, i cant see if they have filled em up tbh, i'll check em now.
where the hell do you put the water and anti freeze all i can see is the coolant (blue liquid)?
and yes i they have greased the bonnet catch, dont know if thats what they should of done or replaced it tbh. was it suppose to be replaced?
thanks for any advice
Fuel filters good for 150k so it'll be fine.
It goes in the coolant bottle! as long as its between min and max I wouldn't worry about it.
Greasing it should be fine.
hi BMH
how are ya?
thanks for that i was told that it increases the MPG if its replaced, i wanna ask you couple of other questions if thats ok?
you on msn now?
hi BMH
how are ya?
you on msn now?
thats a myth... as above will be just fine for 150k at least before you need to think about changing it. A clogged air filter can effect MPG.
your car will start to lack power after period of time if you dont get the fuel filter changed
The fuel filters fine for 150 minimum. Trust me unless you've been noting a propbema nad you'd know why ie throwing rags down the fuel tank. then its fine.
