I want a front plate that fits perfectly on the front bumper, with no overhang. Standard width.
Get some measurements mate and i'll see what I can do.they are not a perfect fit though the ones i have seen
they always seem to short etc
Slightly smaller may be the way forwardThe standard legal font and spacing would not fit in the recess without overhang on the lower grill, believe me![]()
How about a mod that stops the rear wiper "dry wiping" when you select reverse?![]()
I've just PM'd you Mr 2427.How about a mod that stops the rear wiper "dry wiping" when you select reverse?![]()
:approve:
Dan, but what if it's raining at the front and not at the rear? :rasp:
That always happens when I cross from Yorkshire to Lancashire. As soon as you hit the Red Rose, the sun just disappears.:approve:
I could probably arrange a HID group buy if there was enough interest.A kit for dewipering the rear of the car, looks a lot cleaner and is something I am looking into doing, so maybe some instructions and a custom smooth plate where it would have fitted or just a grommet and whatever else is needed.
And also some replica arch liners for all types of bumpers as I know they are in demand. People don't wanna pay £30 each for them from renault so if you could undercut this I know I for one would buy.
Single wiper kit?
HID/Xenon kits?
Just some suggestions....
Some OE RS look pedals for the Dynamique with a tab on the go pedal for heal/toeing...
Nothing's impossible, we'd need originals of each though. Leave it with me.Some OE RS look pedals for the Dynamique with a tab on the go pedal for heal/toeing...
Good suggestion![]()
Can nothing be sorted with the arch liners then, I reckon you could make quite a bit from those
Home, sweet home!That always happens when I cross from Yorkshire to Lancashire. As soon as you hit the Red Rose, the sun just disappears.
Strange, works the other way for me Mr Leach!![]()
Being able to switch on the rear fogs without the front ones.
There must be a loop wire between the two. You should be able to take that out and run a live from the sidelight switch to the rear fog switch for that.....
Fit an Authentique's fog stalk![]()
a quieter indicator ticking noise :quiet: when indicating![]()
Really?
Just annoys me when someone is behind me with fogs on and i have to switch my fronts on to, to give em some back!
we need a third "click" on the stalk for all combinations... lol
how about a kit which will adapt the rear clusters to make both fog lights work instead of just 1? should be easy to do as the bulb/holder are already there. I know you can just run the live feed from one light across the bumper to the other... but would be good if a kit could be made up with the correct connectors etc.
