How much engine coolant?
Car  R35 GTR
Tried searching but only come up with guides and that it will cost £40.lol.
Exactly what quantity of coolant would i need please?
i changed mine on thursday, got 5 litres of renault spec d coolant for 24quid (cheaper than that if you go gsf but there isnt one near me :()
ive used it all up and just need to top a bit up 2day with some water as the levels has dropped and settled now
remember that if the engine is cool. when you fill it up it will take more after the engine is warmed up as the thermostat will open and fill the rad.
Rite ive just tried to drain the coolent on mine...
Ran some flush through the system, then disconnected the bottom rad hose (passenger side underneath the air box).
But its only seem to of drained 2L of coolant i.e ive put 2L of new stuff in and its completly full after taking it for a run and letting it tick over..
Guessing i havent done it correctly?
Can someone explain please
Gray sure you've taken the bottom hose off? As in one of the 2 at the bottom of the rad?
Blow down the cap see what happens.
Yes i looked for the lowest hose on the car..
right at the bottom of the radiator i only disconnected 1 hose?
blew down the cap and nothing else seemed to come out?
if you look at the side of the engine block you will see 3 screws going in from the side the top one is the bleed screw, this will release a load more coolant, you use it to bleed the air out of the system when topping up with new stuff
i will look for a pic to show you fella hang on
the screw is a 10mm bolt
if you look at the piccy it goes into the engine block from right to left, you can just see it in the pic between the hillpower elbow and the blue samco coolant hose next to it, just above the edge of the maxogen in the pic
