Small dent...please help.
  Monaro VXR/Cupra TDi
Just found this on the pasenger door yesterday while washing.:mad:
Would like it to be repaired, but it MUST be an A1 immaculate job.
I live in Essex near chelmsford. Willing to travel to get it sorted IF the work is 110% quality.
Anybody know of someone/company who do excellent dent repairs?
Many thanks.:)
  M4 LCI, X1, ZX10R
If they can get to that from behind, most decent places will get that out no problem and it should look mint.
My friend used Dent Magic here in Bristol on his 182, and the bloke did a great job.
MRBILLYUK
  FF Jeden Osiem Dwa
There might be no need to take the door card off . Mine dent was taken out working down the inside of the window .
Al_G
  Honda S2000, C63
I took my LCR to a company in Warrington! Dave (the bloke who runs the company is honestly amazing and managed to get the dent out within minutes (even though another reputable firm couldnt do it).
It cost me £95 but you pay for what you get! Make sure you take it to someone who knows their stuff as they can cause more bad than good!
  172 A Cupwork Orange™
i'v used dent master b4 all they did with mine was put something like a suction cup on the outside and it sucked the dent's out straight away that looks like a dent i had...
  106 GTi
Using newer more update techniques they may not even need to get behind it. Guy I use uses some hot glue technology to pull them.
I still need to sort out getting the two tiny ones I have done on mine. If you and/or butter are planning on getting him to do any at some point let me know and I'll get him to sort mine at the same time. I dont think i've done bad only getting two in 3 years considering how much time it's sat in the carpark outside the gym and cinema.
  Clio 182 & Saxo VTR
I had about 8 dents in my last car, £20 from dent master at work later and it was dent free, didnt need to remove any interior trim.
MRBILLYUK
  FF Jeden Osiem Dwa
I suppose it depends on the location of the dent . I had 3 removed . 1 in the drivers door , 1 in the rear quarter panel and 1 in the roof which he said would be the most difficult as the headlining is bonded to the roof . All removed within an hour and only cost £90 , £60 of which my neighbours shelled out as their little b4astard kids did the 1 in the roof . :mad:
  106 GTi
The beauty of the new techniques means most can be removed without having to get behind, drill any holes and double skinned areas can even be sorted.
  Laguna 2, Westfield
07702206186 - Tracy Denham(male!) from dent devils, (number from 2006 so you'll have to try if its still in use) Top quality work based in Essex.
Hope this helps.
